argarza
Ene 16, 2009, 6:35 AM
Mensaje #2 de 9
(56488 visitas)
Lo más probable es que tengaes instlada una rutina que se ejecuta de manera automática. Casi seguro es una rutina en VBA o un LSP que se añadío automáticamente al archivo acad.lsp. Para saber si es el primer caso, busca un archivo llamado acad????.lsp (los signos de interrogación son por el tipo de versión, pues puede cambiar) en el directorio de instalación de AutoCAD, abrelo y checa que no tenga nada raro, es más su contenido debe ser muy similara o que sigue: ; MODULE_ID ACAD2007_LSP_ ;;; ACAD2008.LSP Version 1.0 for AutoCAD 2009 ;;; ;;; Copyright (C) 1994-2008 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;. ;;; ;;; Note: ;;; This file is normally loaded only once per AutoCAD session. ;;; If you wish to have LISP code loaded into every document, ;;; you should add your code to acaddoc.lsp. ;;; ;;; Globalization Note: ;;; We do not support autoloading applications by the native ;;; language command call (e.g. with the leading underscore ;;; mechanism.) (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2009doc.lsp")) ;; Silent load. (princ) Las únicas líneas de codigo ejecutable son las que no tienen los ; (punto y coma) al inicio y que resalte en negritas. Si tiene algo más borralo y reinicia AutoCAD. Si es diferente déjamelo saber para ver como ayudarte. Saludos
