Jun 16, 2009, 5:19 PM
(8371 visitas)
Sheep Housing and Handling Farm Resources, Facilities and Equipment ...................................................................... 11 Labour ......................................................................................................................................................11 Land..........................................................................................................................................................11 Machinery ................................................................................................................................................11 Housing ....................................................................................................................................................12 Lambing Facilities...................................................................................................................................12 Ventilation................................................................................................................................................12 Flooring....................................................................................................................................................13 Penning.....................................................................................................................................................13 Feeding.....................................................................................................................................................13 Feed Storage ............................................................................................................................................13 Watering...................................................................................................................................................13 Manure Storage........................................................................................................................................14 Canada Plan Service................................................................................................................................14 Building or renovating .............................................................................................................................14 Farmstead Planning.................................................................................................................................15 Key Components of Sheep Handling Facilities ................................................................ 16 Introduction..............................................................................................................................................16 Planning ...................................................................................................................................................16 Facilities Design ......................................................................................................................................16 Use Sheep Behaviour to Your Advantage......................................................................... 18 Herding Dogs....................................................................................................................... 18 Catching and Tipping Sheep .............................................................................................. 19 Chapter 2: Sheep Housing and Handling Farm Resources, Facilities, and Equipment 11 Farm Resources, Facilities and Equipment Adapted from ‘Evaluating Farm Resources and Sheep Production Systems’ by Bill McCutcheon, Former OMAF Sheep Specialist and ‘Housing and Equipment’ by Ian Alton, Former OSMA Director Modified by OSMA (2002) Labour Labour is an essential and important input in a sheep enterprise. If you are too busy to implement proper flock health and to monitor your sheep closely, the productivity and profitability of your flock will suffer. The amount of labour required will depend on your production system, the size of the flock, amount of cropping, degree of mechanization, facility design, and handling system. When evaluating labour requirements consider the distribution of activities on your farm throughout the year. For example, producers with accelerated lambing programs will generally have a higher, but steadier level of work through the year, while operations that lamb once per year will have increased labour during lambing. Producers who produce their own feed will have extra requirements during haying and cropping seasons. The degree of mechanization generally needs to increase if labour requirements are to remain the same as the size of the flock increases. Such things as feeding with large round bales, using selfdispensing grain feeders, and using tractors to clean pens will greatly reduce time requirements, but must be weighed against extra overhead costs. Whatever your feeding and management systems, however, always consider ways of setting up your facilities to make your work easier. Never create extra work by having things in inaccessible locations, or by trying to work through the stock to reach feeders or other pens. The merits of a good handling system cannot be stressed enough for decreasing labour requirements and encouraging proper flock care (see page16). Land The amount of land you will need depends on whether you plan to produce winter feed for your flock and the level of confinement (i.e. grazing requirements) of the flock. The productivity of the land must also be evaluated to determine the carrying capacity (animals/acre) and the estimated yield from crop production. As this varies greatly throughout the province, it is advisable to contact an OMAF Sheep or Pasture Specialist to find out more about your area. Many producers are under the impression that you must own land to be a farmer or raise sheep. In many cases, unless you already own the land, it is likely most economical to rent your land and buildings. The extra debt load imposed on the farming business by buying land may be enough to make the farm business unsuccessful. Unless you have an offfarm source of income to pay for the farm mortgage, renting may be the most viable alternative. Machinery What equipment do you need to operate a sheep enterprise? If you pasture your sheep you may need equipment to clip pastures for weed control and to spread fertilizer. Unless you are overwintering your sheep on pasture, you will need to remove manure from the sheep barn and yards. The equipment needed for this could consist of a 40 to 65 h.p. tractor with a front end loader, a rotary mower, and perhaps a manure spreader. If you are going to be producing winter feed onfarm, baling and combining equipment will also be needed. It may be cheaper to buy your hay and grain than produce it yourself when you consider the cost of the equipment and labour required. If forage and grain are purchased off the farm, the shepherd has the opportunity to expand the flock by using more land for pasture. Hiring custom operators with their own equipment to crop your land may also be a viable alternative. Chapter 2: Sheep Housing and Handling Farm Resources, Facilities, and Equipment 12 Housing Sheep do not require elaborate housing. Although extra considerations must be made for young stock and during lambing, adult sheep do not require a warm barn and can thrive if they are provided with a draft free place to get out of the snow and wind. Remember that animals housed outdoors during winter will have to put energy resources towards maintaining body temperature and, therefore, will have greater nutritional requirements. During periods of high production demands such as lactation or growth, the animal may not be able to eat enough to supply these needs, so production and body condition will suffer. When housing outdoors during the summer, do not neglect to provide shade for animals. When housing indoors, space requirements including floor space and feeder space must be evaluated to determine how many sheep can be housed in a given pen. See page 14 for information on how to obtain building plans for various housing and handling structures from ‘Canada Plan Service’. The most important things to consider when assessing housing facilities are: · Adequate floor space for the number of animals to be housed. Ewes require 1020 square feet depending on the stage of production. (See The Code of Practice recommendations at the back of this binder) · The ease of feeding, cleaning, and handling the flock · Ventilation and drainage Lambing Facilities Lambs are born with little fat cover and a low energy reserve. Hypothermia is the main cause of lamb loss in Ontario and lambs that are exposed to cold, wet conditions are very vulnerable. Therefore, an insulated area is a must if you are lambing in the winter. Once lambs are dried off and have a good start, they are better able to handle lower temperatures. Many producers will isolate ewes with newborn lambs into mothering pens for a day or two. The purpose of these pens is to allow the ewe to calmly accept her lamb in safe and stress free environment. This may be particularly important for ewes the first time that they lamb, as they are more likely to reject the lamb(s). As well, other ewes that are close to lambing themselves may attempt to ‘steal’ newborns. Pens should be clean, easily disinfected, draft free and constructed so that lambs cannot become chilled or trapped. They should be no less than 4’ x 5’ in floor size and at least 30” high. Ventilation Ventilating barns properly is an important and at times challenging aspect of maintaining a healthy flock. Viruses and bacteria thrive in low quality air and can cause respiratory diseases in animals. This is a particular problem for young stock, which are more prone to pneumonia resulting in poor growth and high mortality. When livestock are housed in barns the air should be kept clear of excess humidity and heavy odours. This is complicated by the fact that byproducts of forage digestion are water and heat, and a flock of sheep can produce very humid conditions in a barn in a short period of time. The purpose of a ventilation system, therefore, is to replace the moist, warm air inside the barn with cool, dry air from outside. Providing adequate ventilation during the winter is a balance of circulating enough outside air to keep humidity down, while maintaining adequate warmth (e.g. prevent water lines from freezing, protect lambs, etc). Ventilation during the summer may be even more problematic if the outside humidity equals that within the barn. Barns can be ventilated naturally or by forced air fans. Open style barns are usually well enough ventilated but some of the larger ones require more elaborate systems to get air circulating through all areas. For closed barns, opening windows away from the wind will help solve the problem, but take care to prevent drafts directly onto the animals during the winter. Reducing stocking density, shearing animals, and providing dry bedding will help avoid problems with humidity in both the summer and winter. To learn about specific types of ventilation systems or if you are in doubt about the ventilation capacities of your barn, contact your provincial specialist to arrange a consultation. Chapter 2: Sheep Housing and Handling Farm Resources, Facilities, and Equipment 13 Flooring Floors are typically either earth or cement. Earth floors are warmer, softer, and more economical, but may be hard to maintain. Good drainage is needed to keep the floor dry. Concrete floors are very hard and unforgiving, but are easy to maintain and sanitize. Plenty of clean, fresh bedding should be provided at all times. If it isn’t clean enough or bedded well enough for the shepherd to curl up on, then it isn’t adequate for the flock either. Penning Ideally sheep should be divided into group pens according to nutritional requirements. This allows the shepherd to meet the nutritional needs of the animals as closely and economically as possible (See Chapter 7 for more details). Animals may be penned according to the following groups: · open/dry ewes on maintenance diet · rams · ewes preparing for breeding (flushing) · type of pregnancy (i.e. single or multiple pregnancy; if pregnancy testing performed) · ewes with newborn lambs · lactation demands (e.g. number of lambs, stage of lactation) · market lambs based on age, weight, and/or finish · replacement ewe and/or ram lambs (may feed differently than market lambs) Feeding Sheep should be fed in a manner that does not require the shepherd to enter the pen with the flock. Walkthrough (feeder divides two pens, allowing producer to feed both pens) or bunk feeders accessible from alleys should be used. Adequate bunk space must be provided to allow all sheep to eat at the same time with some space left over. This allows smaller, more submissive animals to eat at the same rate as the rest of the flock. This helps maintain an ideal average body condition in the pen, and helps decrease the incidence of overeating disorder in feeder lambs (see Chapter 8). See the Code of Practice at the back of this binder for details on feeder space required per head. There are various styles of feeders available. Feeders should be designed to keep sheep from walking on the feed and to prevent feed from being pulled onto the ground. This helps keep feed clean to minimize parasite loads and decrease feed wastage. Commercially produced feeders will last longest, but for economic reasons adequate feeders can be made from wood. See page 14 for information on obtaining building plans for sheep feeders from ‘Canada Plan Service’. Feed Storage Grain must be kept dry (i.e. off the ground and protected from the elements). Grain that gets wet is prone to developing moulds, which are potentially harmful to the sheep. Grain should also be protected from rodent infestation as much as possible. Protecting hay from moisture and sunlight helps to maintain nutrient quality and prevents wastage. Watering Where possible, automatic watering devices should be provided. In cold barns you may have to consider heated automatic bowls and insulated or heated pipes. Approximately 40 ewes, 10 rams, or 5075 feeder lambs can use one watering bowl. Water is the most important and often the most overlooked nutrient in a sheep’s diet. Sheep do not like dirty water and will consume more if it is not fouled. Bowls should be checked daily and cleaned when needed. A quick scoop that only takes a second will clear the bowl of hay, straw, or manure. If you are using ponds or dugouts as a water source, watch for build up of bluegreen algae. This alga can be potentially fatal to livestock and humans. Chapter 2: Sheep Housing and Handling Farm Resources, Facilities, and Equipment 14 Manure Storage Store manure away from buildings and corrals to prevent runoff into sheep housing areas, water sources, and feed supplies. Take precautions when spreading manure to prevent contamination of water sources and oversupplying nutrients to soil. New provincial regulations regarding the handling and storage of manure will soon be in place. Contact OMAF to learn about these regulations and how to implement a nutrient management plan on your farm. Canada Plan Service Canada Plan Service (CPS) is a nation wide network of agricultural engineers and livestock specialists concerned with the planning, design and construction of modern farm buildings. Their goal is to gather ideas from across Canada and then develop construction and management recommendations. In this way, uptodate building technology and farmstead management practices are available to all Canadian farmers. Ten technical committees, with membership drawn from each province, develop the Canada Plan Service publications. Publications take the form of detailed construction plans or management and construction leaflets. Each province distributes the plans and leaflets according to its needs. (See their website (www.cps.gov.on.ca or contact OMAF (15198263100) for information on how to order building plans). The CPS Information Resource focuses on the following areas: 1. Farm Structures and their Environments 2. Waste Handling and Storage 3. Animal Care and Comfort 4. Crop Handling, Storage, Processing and Conditioning 5. Rural Environment 6. Systems Engineering A few of the plans available specifically for sheep housing and handling include: · Pole frame sheep shed · Slotted floor sheep barn · Sheep drylot unit · Shearing floor and fleecesorting table · 6sided sheep feeder · Adjustable feed bunk · Mineral boxes · Lamb creep feeders · Feed rack · Fence line and walk through feeders · Sheep corral fencing and gates · Loading chute Building or renovating When a decision is made to construct or make modifications to a farm building, new building code regulations must be considered. Farm building construction in Ontario is primarily regulated by the Ontario Building Code 1990. This code, proclaimed on October 1, 1990, recognizes farm buildings to a larger extent than previous Ontario Building Codes. It is necessary to obtain a building permit for all agricultural construction projects in Ontario. Manure storage, grain bins and silos all fall into the definition of "farm buildings", and along with all other farm structures, will require building permits. Chapter 2: Sheep Housing and Handling Farm Resources, Facilities, and Equipment 15 Farmstead Planning When planning a new building or adding to an existing farmstead, you must consider such things as: · Site drainage · Services (lanes, power, water supply, waste disposal: · Security · Separation distances for snow and wind control, ventilation and disease control · Distance separation from residences for control of noise and odours · Municipal Regulations Office of the Ontario Ministry of Agriculture and Food can provide many Fact sheets and other publications pertaining to the planning of farm buildings, manure storage, etc. Check with your local municipality and OMAF early in the planning stage. The construction of livestock facilities is usually only permitted in agricultural zones. In addition, the location of the facilities is often restricted by setback distances from roads, lot lines, neighbouring houses and land uses. Usually these setback distances are based on the Agricultural Code of Practice and take into account: · Number of animals on the site. · Type of livestock · Management system · Degree of expansion · Manure storage Chapter 2: Sheep Housing and Handling Sheep Handling Facilities 16 Key Components of Sheep Handling Facilities Anita O’Brien, Sheep and Goat Specialist, OMAF From the OMAF Sheep Industry Update, 2001 (Modified by OSMA 2002) Introduction Welldesigned sheep handling facilities are an important ingredient for successful sheep production. The sheep producer will find few other investments that can match handling facilities with respect to labour efficiencies and savings. Most producers will only build or purchase one handling facility in their lifetime, so planning is essential. Existing paddocks, laneways, and barnyards should be incorporated into the handling system to allow for ample space when the flock is held in the yards for extended periods of time. Sheep need to be moved smoothly between these areas with a minimum of fuss. To achieve this, a producer needs to understand how good design encourages the sheep and lambs to move ahead through the system without balking, thereby keeping problems for workers to a minimum. Welldesigned facilities are easy to operate, saving stress, labour, and their associated costs. Planning Sheep handling in ‘makedo’ pens is not only hard, difficult work, it is outright unpleasant, resulting in important jobs like vaccinating and deworming being delayed or not getting done at all. To ensure that the handling facility will accommodate all the required jobs, make a complete list of the operations that will be carried out, and consider how these jobs will be done in the plan. A useful checklist includes: · Shearing, crutching, sorting, deworming, vaccination, body condition scoring, pregnancy scanning, foot trimming, foot bathing, weighing, loading and sale of sheep Factors to be taken into consideration · Best location for the facilities based on sheep behaviour (see list on page 18). · Size of groups the facility will need to handle · Amount of labour available for working the sheep in the facility · Modification of existing facilities, new buildings, or purchased portable yards, and · Costs involved Facilities Design In simple terms, handling facilities comprise the following areas: low density holding areas, high density holding areas, forcing (or crowding) area, and a handling chute (or race). Most producers can use nearby pastures and laneways as their low density holding areas. These areas need to be secure enough to prevent escapes (particularly lambs) from one area to the next, so consider using net wire fencing with openings no larger than 15cm by 15cm secured to closelyspaced posts. High density holding areas need to be built with medium to strong fencing materials. A density of two sheep in full fleece per square metre allows enough room to drive the group into the yards, while leaving space for gates to swing. It is particularly important that these areas are long and narrow so that groups are easily controlled while being driven up into the forcing (crowding) pen. If greater capacity is needed, it is better to lengthen them, rather than making them wider. Figure 1: Sheep in handling system Chapter 2: Sheep Housing and Handling Sheep Handling Facilities 17 Forcing pens should be designed to ensure an even flow of sheep into the handling chute. Therefore, avoid square or triangular shaped pens that have corners where the sheep will get ‘stuck’. Forcing pens generally have a swinging gate that can be brought in behind the animals to crowd them into the chute (Figure 1). The handling chute should be solid sided to prevent legs or horns being caught; high enough to prevent jumping; narrow enough to prevent animals from turning around (adjustable width for handling sheep vs lambs); and designed to allow the sheep in the forcing area and in the chute to see the animal ahead of them. Some producers may opt to place a weigh scale within the chute. Depending on the set up of the pens leading from the chute, the gate at the end of the chute can be used to sort (draft) animals into different management groups (e.g. market lambs vs replacement stock etc.). For producers that are just starting their sheep operation, the following example may not be feasible right away. However, with the overwhelming advantages of having a good handling system in place, all producers should think about ease of handling and have an overall plan in mind when designing their corrals and penning. Other facility designs are available from the Canada Plan Service (see page 14) Chapter 2: Sheep Housing and Handling: Sheep Behaviour & Herding Dogs 18 Use Sheep Behaviour to Your Advantage Anita O’Brien, Sheep and Goat Specialist, OMAF (From the OMAF Sheep Industry Update, 2001) Efficient use of sheep handling facilities requires that sheep move through the facilities as smoothly and rapidly as possible. By understanding sheep behaviour, producers can use this knowledge to their advantage in setting up and using their handling facilities. A brief review of some important aspects of sheep behaviour as it relates to handling and movement: · Sheep do not like to be enclosed in a tight environment and will move on their own accord into large areas. · Sheep move toward other sheep willingly · Sheep move away from workers and dogs · Sheep have good longterm memories (relative) especially with respect to unpleasant experiences. · If given a choice, sheep prefer to move over flat areas before up an incline, and up an incline before moving down it. · Sheep prefer to move from a darkened area towards a lighter area, but avoid contrasts in light. · Sheep flow better through facilities if the same path and flow directions are maintained. · Stationary sheep are motivated to move by the sight of sheep running away. · Sheep will balk or stop forward movement when they see sheep moving in the opposite direction. · Sheep will move faster through a long, narrow pen or area, than through a square pen. · Sheep move better through the race if they cannot see the operator. · Sheep will more willingly move toward an open area than toward what they perceive as a dead end. · Sheep react negatively (as do all livestock) to loud noises and yelling and barking. · Young sheep move through facilities easier when their first move through is with well trained older sheep. Many years of observation, by many different people, have gone into establishing the above listed points of sheep behaviour. They illustrate hat certain actions and reactions by sheep are very predictable, and can be used to the producer’s advantage in all aspects of sheep management. References: Kondinin Group. 1990. Yards ‘n’ Yakka. MidWest Planning Services. 1994. Sheep Equipment Handbook. Herding Dogs A welltrained dog can save the producer a great deal of effort when herding and moving sheep. Many breeds of dogs are used on sheep farms throughout the world. In Canada, the black (or brown) and white Border Collie is perhaps the most popular. In selecting a dog, make enquiries, watch sheep dog trials and, if possible, enlist the aid of an experienced handler. A purebred dog is by no means essential, but a welltrained dog is. Most breeds of herding dogs have strong instincts to stalk and chase livestock. If these instincts have not been properly channeled through training, dogs will generally do more harm than good by chasing sheep in the wrong direction, running through the flock, or becoming overly aggressive towards the sheep. Even with welltrained dogs (depending on their temperament), you may wish to restrict their use to gathering sheep in large areas, rather than in small pens or handling systems. Dogs may become overly excited with sheep in confined areas, particularly if the flock isn’t moving well. The sheep will remember the frightening experience and may be reluctant to enter the handling system the next time. If you buy a professionally trained dog, be sure to take some time to learn commands that the dog will understand; improperly trained people may be just as frustrating for dogs, as poorly trained dogs are to shepherds. Chapter 2: Sheep Housing and Handling Catching and Tipping Sheep 19 Catching and Tipping Sheep By: Les Jones; Former OMAF Sheep Technician (Modified by OSMA 2002) Catching Sheep At times it is necessary to catch and handle individual animals. If you do not have a handling system and have to catch sheep in a pen, use gates or hurdles to make the pen as small as possible. Do not get into the habit of chasing sheep around a pen. This is not only tiring, but is potentially dangerous for the sheep and the person trying to catch them. Compared to horses or cattle, sheep are not large animals, however, they are very fast on their feet and very strong for their size. Many people have been injured by trying to catch a sheep improperly. Repeatedly chasing your sheep will also make them flighty and difficult to work with. Maneuver the sheep into a corner, extending your arms or using a portable gate to form a visual barrier. Approach the sheep slowly and calmly. The sheep will likely attempt to escape but will probably not move away from the wall, so its moves can be anticipated. To properly catch a sheep, reach for one of three places. · Under the chin: Approach the sheep between its shoulder and flank (if you approach too close to the head, the sheep will likely be able to duck away from you). Cup your hand under the chin and point the nose up to stop the forward motion. Be sure that you get your hand on the bony part of the jaw, not on the throat or you will think you have caught a horse and will be dragged around the pen. Place your other hand on the tail/rump to prevent the sheep from backing away from your hand on its chin. If you are near a wall, you may wish to gently push the sheep against the wall to prevent sideways movement. · Hind leg: Catch the animal by one hind leg, positioning your hand just above the hock. Move your other hand up to control the head as soon as possible. As adult sheep are still able to kick strongly while being held just by the leg, this method generally works best for young, lightweight animals. · The Flank: Catch the animal by the front part of the hind leg as near as possible to the body. Place your free hand up to the head as soon as possible. If you control the head the rest of the animal will stay there as well. Whichever method you use, remember that the wool is not a handle and should not be used as a means of controlling the sheep. This is particularly important when handling animals near slaughter weight, as wool pulling is a significant cause of muscle bruising and meat wastage. To move the sheep lift the tail and let the head down a little, and anticipate that the animal may try to bolt. Tipping or Turning Sheep Once the animal is caught, you may wish to ‘tip’ the sheep onto its rump to trim feet, inspect the udder etc. Surprisingly, sheep in this position struggle very little and are generally easy to work with (Figure 1). There are a few methods of getting the sheep into this position. Depending on your preferences, the following method is generally the least tiring and easiest on the handler and the sheep. These instructions are for a righthanded person, if you are lefthanded you will likely find it easier if you reverse the directions. Chapter 2: Sheep Housing and Handling Catching and Tipping Sheep 20 1. Starting position: · Stand the sheep in front of you · Hold the sheep’s head in your left hand, placing your hand under the jaw · Your left knee should be near or just behind the sheep’s left shoulder · Your right leg should be touching the sheep’s side near its left hip · Your right hand on the sheep’s back over the hips 2. Turn the sheep’s nose away from you and right around as if it was trying to reach a spot on its back just behind the shoulder. As soon as you bring the nose around you will feel the weight of the sheep lean against your legs. 3. Put enough pressure on the hips with your right hand that the sheep cannot pick its back feet off the floor. Take a step back with your right leg (your back not the sheep’s!). The hind end of the sheep will start to go down. 4. Continue to bring the head around until the animal is sitting down with its back leaning against your legs. Steps 24 should be done in a smooth motion. The mistake most often made by beginners using this method is to move the wrong foot. Remember to pivot on your left foot and step behind you with the right foot. roberto sanchez,RCDD Facilius Per. Partes in cognitionem totius adducimur. Seneca -Es mas fácil entender por partes que entenderlo todo-
