arkifer
Ene 21, 2008, 10:18 AM
Mensaje #3 de 5
(7969 visitas)
hola no se si aun te sirva pero encontre esto es la relacion de kg por m2 dependiendo el claibre de la lamina Table 4A Galvanized Sheet Thickness Gage a Thickness, mm Nominal Specific Nominal Minimum b Mass, kg/m2 30 0.399 0.319 3.20 28 0.475 0.395 3.81 26 0.551 0.471 4.42 24 0.701 0.601 5.64 22 0.853 0.753 6.86 20 1.066 0.906 8.08 18 1.311 1.181 10.52 16 1.613 1.463 12.96 14 1.994 1.784 16.01 13 2.372 2.162 19.07 12 2.753 2.523 22.12 11 3.132 2.902 25.16 10 3.510 3.280 28.21 a Galvanized sheet gage is used for convenience. A metric series would conform to ASME Standard B32.3M, and the tolerances in ASTM Standard A 924 apply. b Minimum thickness is based on thickness tolerances of hot-dip galvanized sheets in cut lengths and coils (per ASTM Standard A 924M). Tolerance is valid for 1220 mm and 1524 mm wide sheets.
